Widgets? I found some simple ones, without
I started out with the incredible, I just now moved into a turbo2. I am use to widgets to turn items like gps, wifi, Bluetooth and airplane mode "On" and "Off".
The widget for the wifi just opens the settings, where in turn can be turn off and on, but not directly from the widget.
Suggestion please. Do I need to install 3rd party or install something else?
Best regards,
Moxie
Did you just try swiping down from the top of the screen? This opens a panel with a number of options. You can toggle wi-fi on and of there and a lot more.
... Thom
And if you swipe with one finger you bring up you notifications. One more swipe down and the settings. OR you can swipe with two fingers and it goes straight into the settings.
