Joanna Davis
Incorrect wifi settings most common problem on p8.So at first go to your Settings>Advanced Settings>Wifi> Select: "Always" .So if you want you can choose "Only When Plugged In" as an alternative. But in this option work only when the device is charging and doesn't forget to connect the device to wifi and Bluetooth.
