New behavior in my Droid Maxx. I cannot get bluetooth, wifi, or mobile hot spot to turn on. There are no apparent errors displayed when I attempt to turn on any of them. Device is not in airplane mode as normal over the air voice/data is fine connecting to both 3G & 4G LTE modes. I've done both hard & soft reboots that don't change the behaviors
Bluetooth screen. I tap the On button, a message comes up stating that its turning on Bluetooth, but after 5 seconds it still lists as Off and no BT icon appears on my status bar.
Wifi: I tap the On button and instantaneously it goes back to the Off position. I've tried turning Wifi on via several different appsand menus, but all have the same result. Wifi icon never appears in status bar.
Hotspot: I have a data plan that includes hotspot, and it's always worked up until now. Same behavior as bluetooth where I click the check box in Settings to turn it on, but after a few seconds the box is simply unchecked again. No error message displayed.
Separately, I've also noticed that the "your app will work better/faster on Wifi" pop up for many apps like Google maps. The checkbox in settings that allows me to turn off that prompt is greyed out and I cannot turn it off like it used to.
Any thoughts?
version info:
android 4.4.4
system:23.3.24
Any thoughts?
version info:
android 4.4.4
system:23.3.24
