Iv'e tried rebooting my phone, wiping my chache partition, resetting my phone memory and it didn't workHave you tried to reboot the device yet?
Perhaps it will resolve that glitch
What device make/model/carrier is it?
You've reset ---as in, factory reset back to stock?Oh boy.You've reset ---as in, factory reset back to stock?
No it hasn't, and the problem just accured this morningHas the device had a recent update and then this issue arose?
)How to do a simulated battery pull on a Huawei P8?
or
- Step 1: Make sure that the power is completely off. Make sure that the phone is not plugged into a charger either. Note: if the keys on the bottom of the device are lit then the phone is on, if there aren’t any lights showing or lit up then don’t worry about whether your phone is on or off, simply go ahead to step 2.
- Step 2: Hold the Volume Down button and then the power button and continue to hold these 2 keys for 20 secs (count out loud it could take 15-30 sec).
- Step 3: The phone should power cycle, powering back on to full.
Now check your Wi-Fi Connection and see if it is working.
- Step 1: Make sure the power is completely off and that the phone is NOT plugged into a charger.
- Step 2: This time instead of the Volume Down key use the Volume Up key. Hold the Volume Up and the Power key simultaneously for 20 seconds and see if anything pops up on the screen.
- Step 3: Release the Volume Up and Power keys if/when you get a response.
- Step 4: If you get some options then use the volume down key to cycle through your choices. Look for an option to restart or reboot. (don’t do the wipe data/factory reset option… yet… that’s kind of a last resort)
- Step 4: Once selected use the power key to execute.
- Step 5: The P8 should reboot.
There are a bunch of random numbers on the baseband and 2 sets of random numbers on IMEI.Check in Settings, About Phone, and see if your baseband is correct or unknown.
Also check if your IMEI is correct or unknown.
None of them worked. Give me more optionsThere are a few things you can try.
Turn off phone and remove and replace sim reboot, check wifi.
Toggle Airplane mode on/off , check wifi
No, i don't know what that isDo you happen to have CM Security installed on your phone?
