Help Wifi connection unsuccessful
dgbg11
I downloaded the Pandigital android update to my white pandigital novel just as they showed online. The applications ie B&N etc did not load and when i try to connect to my WiFi it shows that it found my router but when it trys to connect I get the message "connection unsuccessful". I'm extremely frustrated. i tried turning off the router etc. nothing.....
Did you try restarting?
I get this all the time on my Romd rooted white.
I think it's just a shoddy wifi radio.
A restart usually fixes it for me, if not I might would restore settings and go from there.
