Help Wifi delays 3g connection until reboot
dalsen
Having a problem with my milestone 2 since I've started using it to connect to my home wifi network (used it for a couple of months after buying without using wifi - only 3g). I've found that if I use wifi and then later turn it off and attempted to re-establish a 3g/hdspa/edge link, instead of happening straight away as it usually does, it takes around a minute to establish the link. This continues irrespective of how many times I turn 3g on and off (I typically leave it/gps/wifi/bluetooth off unless I'm using them to save battery power) or how long it's been since I used wifi, until I power the phone off and back on, after which toggling 3g goes back to taking one or two seconds....until the next time I use wifi, etc. Kind of annoying, wondering if anyone else had run into something similar and found a solution/workaround (although googling suggests not :( )
Edit: Never mind, issue seemed to be caused (somehow) by the toggle widgets (was using GO widgets having just started using the GO launcher, switching to ZDbox toggle widgets resulted in the issue disappearing :) )
