Help WiFi direct
I have a question.
how can I share files between 2 phones over local only wifi, without having a router, and without the phones being Wifi Direct certified?
I had a Samsung that had wifi direct and I guess that's what you'd need, but my phones do have WiFi hotspot so I can make one connect to the other.
How can I send files from the old one to the new one using the wifi tethering?
Check out "SHAREit - Connect & Transfer"
https://play.google.com/store/apps/details?id=com.lenovo.anyshare.gps
Check out "SuperBeam | WiFi Direct Share"
https://play.google.com/store/apps/details?id=com.majedev.superbeam
Check out "Fast File Transfer"
https://play.google.com/store/apps/details?id=com.floriandraschbacher.fastfiletransfer
One of those will probably work, plus you can also try Bluetooth if not -
Check out "Bluetooth File Transfer"
https://play.google.com/store/apps/details?id=it.medieval.blueftp
