Hello Guys.
I bought a WiFi Disk-Case Systec PX-4709 or Powson PX-4709. Because its very small.
For this disk exists a app named "AirStor" (Power7 Technology).
A test is in androidpit. this device is shown in the app, but i cannot move anything or create folders on the device.
The software is very too basic. Oter software like "WiDisk" and so on is not working too.
So i tried with "Total Commander" and FTP or LAN plugin. But with LAN (port 80) and FTP (port 21) i get no access.
A try with "ES Datei Explorer" and the LAN, WEB and FTP options but the device will not be found.
The procedure to have access to the drive is:
- Connect to accesspoint / Server of the drive over WiFi-Network
- Start the app AirStor: the device is shown now as empty
- It is possible to change the drive parameter like SSID and IP, but this was not function. So i take the default
- Select a file and copy it to the disk, but this is not going
With which software can i get a access on the device? I see the mac and the IP address, but i not know the ports for communication.
Can i find out which communication-protocols are running and on which port? Or which protocol is using by AirStor?
Unfortunately in Windows i cannot have access too. I cannot ping and see the device.
Over USB i have with Windows 7 pro 64Bit also no access. Its only possible to connect with AirStor?
Can anybody help me?
Kind regards
robitobi
Kind regards
robitobi
