Wifi/GSM signal bar chart
Hawker
Android Expert
On the S4, you could click on the battery graph and it would expand also showing how often your wifi was on/off, gsm signal quality etc.
Is there any way of showing this information on the S7?
When you click on the individual battery listings it will give more data such as Cell Standby which shows how much time and battery used on cell usage.
Thanks for replying Toto39. :)
I realise that thanks, but the overall bar charts that would get shown when clicking on the battery graph (ie. on Lollipop ROMs) were very handy which would also let you quickly see if your wifi was switching off correctly, and summary of signal strength by green/amber/red colouring.
This sort of thing:
