WiFi Hot Spot
I've been trying to read up on the Droid X's Wifi Hot Spot, but I can't find much about it other than little bits and pieces.
From what it sounds like is that the Droid X will act as a wireless router for up to 5 devices. So I can fire it up, and my laptop can connect to it to get internet access on my laptop.
I've read that up to 2GB/mo data will cost around $20/month through Verizon. Is this on top of the monthly data plan that I already pay for?
I've also read that there are some phones you can root and once rooted, you can get unlimited wifi hot spot.
I'm sure it will be awhile before the Droid X gets rooted, but until that happens, I'd like to know what my options are.
You can search out for lower payments for other plans but I think they will be near to 20$ per month. Just find out other hot-spots which provides you reliable plans to make use of them. AS the Droid x acts as a wireless router,I think it will be more beneficial and compatible with your laptop only the matter is its higher price.
