My wife and I have had the exact same Galaxy S3 phone since November. They are the same OS number, build number, etc. Exact same.
Android Version: 4.1.2
Model Number: SCH-1535
Baseband Version: I535VRBMB1
Kernel: 3.0.31-861013
Same on both phones
As of this morning, my phone is having issues connecting to my home wifi network, which has not changed in years, while hers works just fine. It connects just fine, but has no internet access. All other devices in house connect just fine too, so it has to be something on this phone.
Mine is obtaining an IP Address that is outside the scope of my DHCP setup. When I log into the router, it shows my device listed, but shows "Static IP".
DHCP Scope: 192.168.0.50-70 (20 addresses, not all taken)
Hers: 192.168.0.59
Mine: 192.168.0.104
I have checked, re-checked, deleted and re-connected to my network a dozen times, and it still gets the same IP address. And I even went through and configured it with a static IP within the scope range to see if it would work, but it has not.
I've rebooted the router, 3 times. Restarted my phone 3 times. All the while, her's keeps connecting just fine.
I'm quite network savvy and have spent hours looking up solutions, but I haven't found any similar problems anywhere, only the general "Can't connect" threads. But mine connects just fine.
Hopefully someone can shed some light on why it would be working just fine last night, as of this morning it is not.
Thank you
Same on both phones
Hers: 192.168.0.59
Mine: 192.168.0.104
Thank you
