wifi issues
  • Start date Start date
A
Android Question
Guest
I have a droid 3 and my wifi and bluetooth wont connect. My wifi ends up saying error. I tried dialing *#*#526#*#* but it disappears when i type it in. Wondering if there is anything else I can do.
Hi and welcome to Android Forums!
Assuming you've done a battery pull or rebooted your phone and turned off and rebooted your router, you can try to go to Settings > WiFi then long press on your connection and tell it to forget the connection. Then try to reconnect.
Failing that, if your router supports it, try changing channels.
You can also join us in the link in my sig and discuss this in more detail in the forums.
