Wifi keeps disconnecting
Hi,
When i'm connected to my router at home via wifi, the connection randomly drops from time to time. My laptop and TV is fine which are both running via the internet. The setting is set to stay connected always, even when the screen goes black.
Does anyone have a resolution for this? Perhaps static IP? if this is the answer, what should the settings be?
Many thanks in advance for your help, it's much appreciated
Gavin[FONT=&quot][/FONT]
mine has been doing this since the upgrade. I've contacted SE and I'm waiting for a response. Will let you know when/if I get a response.
Just heard back from them and all they said was do a reinstall. So I did still had the problem so I switched off the phone took the battery out left it for 30 secs turned it back on and lo and behold the problem is solved. If only all this phones problems were that easy to fix.
Mine kinda sucks. I have the switchpro widget and I will press it on 2-3 times sometimes with no luck. If I go to settings, it will say "unable to start wifi" (WTF), but one press is settings and it almost always starts back up.
That's what mine does too. It disconnects randomly but then when I go into wireless controllers then one press on wi-fi settings and it always starts back up.
