I keep shutting off wifi and it keeps turning itself back on. I can't find anything in the settings that would allow it to turn on by itself. Anyone got any ideas?
Settings->(Wireless and Networks) More Settings-> Mobile Networks -> Automatic Connections -> Click "Sprint Automatic connection"
When this is checked the wifi will turn on automatically, leave it unchecked to maintain control over your wifi settings
Wow. I had no idea such a setting even existed. This seems to explain it all. Its unchecked now. If anything happens again, I'll post here. Thank you for your answers!
No problem, had the same issue when I first got the phone lol
its kind of a pity as I actually LIKE this feature. but alas at work the wifi is so weak its useless (enough to get a ssid not enough to actually use it) so turning on wifi essentially kills data. if I could tweak it so that wifi below a certain strength threshold would be ignored (by the automatic portion) I would keep it on.
thanks you for telling how to stop this it was getting annoying it turning itself on like that![]()
