Wifi lost during sleep/lock
Hi there,
I just bought a Wiko BLOOM that runs Android 4.4.2.
It runs smoothly, except for one thing:
It keeps losing the wifi connection during sleep, although the wifi-icon is still on. Turning wifi off and on again restores the connection, but this is getting annoying.
My advanced wifi-settings are:
Network notification: off
Keep wifi on during sleep: Always
Scanning always available: off
Wifi optimalization: off
Passpoint: off
Any suggestions? I have an old Alcatel 5020, which never had any problem....
Cheers,
Cees
My HTC one x+ will turn WiFi off during sleep, even though it the advanced WiFi settings are set to keep it on, because my power save function turns off all data connections during long periods of inactivity. Do you have a similar mode? You may be able to disable some of the power save functions.
But does your HTC turn the wifi off completely, like even the wifi-icon disappears?
Cause my phone does not seem to turn it off completely. It claims it's still connected (icon and all), but every other app you start complains about the absence of any connection.
Couldn't find any power save functionalities on my phone though.....
