Wifi not turning on
  • Start date Start date
A
Android Question
Guest
Dear All,
I have Samsung GS2 and the problem is my wifi not turning on
it appears to be light green for some time then greyed
any suggestions plz
Worried
Two things come to mind:
1. You have "WiFi Power Save" mode enabled. To disable, perform the following steps.
Dial *#0011#
Press menu key
Select WiFi
Middle of display is button for WPSM; If green, press to disable.
It will cycle WiFi to enable.
2. There are many downloadable apps that have the ability to disable wifi between certain hours. Be sure you don't have something like this installed and enabled.
