WIFI or Provider's Network?
Hi Folks:
Is there an icon that tells me if I'm connected to a WIFI or the cell provider's network?
Is there a way to see which WIFI I'm using?
Thanks
Larry
In the upper right you should see WiFi, cellular and battery icons - mine is showing silent mode, WiFi, cellular and battery in that order. If WiFi is off it won't show. If you're in airplane mode cellular won't show but a little airplane will, they change depending on what's turned on or off.
If you pull down twice from the top you should be able to see what WiFi network you're connected to.
