Wifi Prefered Network Ordering?
tee4cute
Hi,
I'm wondering that "Is there any way to configure prefered wifi network ordering?"
I'm quite annoy to manually switch wifi network at my office. Because I always use wifi hotspot when I'm out some where but the problem is that wifi hotspot coverage also cover my office too.
It's automatically connect to the last wifi added at first. So, if I add hotspot network to the saved list after my office network, it'll automatically connect to hotspot network instead of my office network if it finds both 2 networks in coverage.
I'm quite sure that the android OS does not provide the feature to order prefered wifi network because I've looked around every corner in settings.
The only solution seems to be using some applications to control this.
Does anyone have the same problem with me? And how can you figure it out?
Thanks!!!!
