Help WiFi Problem After JB Update
ViralGold
Hi,
After updating to JB this morning i have had problems with the WiFi connecting. It just constantly tries to connect to 1 of the networks i use but won't connect. Turned WiFi off now as it was taking it's toll on my battery.
I contacted Vodafone > Samsung and all i was told was do a factory reset :mad:
Before i do that i thought i would ask here to see if anyone had an answer for this.
Thx:smokingsomb:
UPDATE :-
Hi again,
OK so i thought i would reroot my phone (with siyah kernal) then do a recovery to before the JB update and take it from there, reinstall JB and hope that fixed the problem.
Well, after i rerooted the phone the Wifi picked up again right away like it used to. Woohoo. Tried restarting the phone a few times just to check and every time it has picked up the network within seconds :D
Why? I couldn't tell you, but rerooting seems to have worked :D
Fingers crossed that will fix the problem. So so glad i never done a factory reset like Samsung advised.
Peace
Hi,
Yeah i have tried to forget the network a few times but it still keeps saying connecting when i try and connect to it after i enter the password.
I have noticed it sometimes says scanning and then saved / secured but then reverts straight back to connecting.
I have a similar problem as well, it happens with some networks I happen to connect now and then, it keeps reporting "Connecting" and then it says "Network disabled due to poor connection". It connects fine with the router I have at home.
Hi,
That is my home network, the 2 computers running off it are fine so i don't think it's a signal problem. Thx for the input though ;)
