hello android forums,
i have a problem regarding my Samsung galaxy S3. The problem is that my device is only connected to WIFI when i am in the room that possess the router. but when i move away i no longer get connected to wifi. when i move away from the room containing router, although my device shows the wifi in range, the wifi is only saved and it does not get connected.
the things that i have already tried.
1) changing the wifi setting from DHCP to STATIC.
2)changing the router's channel and width
3)mixing b.n.g mode
4)used wifi analyzer to check if other network is interfering with mine
5)tried to use the wifi in different routers still the problem persists
3)mixing b.n.g mode
