Help Wifi Problem
allan156
Hello
I am using a zoom x6 router with wpa2 and have only managed to connect twice and both times the connection was lost in less than a minute. I was able to connect to a wep network at work but the signal strength was poor so it dropped out but would reconnect ok.
I have tried with no encryption but it still would work.
Excellent signal strength changes to out of range when I attempt to connect.:(
Any ideas?
thanks Allan.
You know, I have similar(?) problem with on of the wireless routers - I can connect to it, it gives me an Ip address, but internet just does not work! Have no clue or solution why is that or how can it be cured...
