i have wifi problem with my asus ee pad tf101 . sometimes its wii not working when its in sleep mode . It shows that its connected but i cannot browse the internet. I have to turn in off and then turn it on to work. Is there any solution for that.
You could try checking the advanced wifi settings. I *think* the default setting is for the WiFi to 'go to sleep' every 15 minutes. If you set it to 'never' then it will use more battery but you shouldn't have this problem anymore.
