Help Wifi Problems still not solved
Muk343
I tried using my laptop as wifi router (using intel my wifi technology) for browsing internet on my galaxy ace GT S5830. I works fine for about 10 seconds and then stops browsing. Though the status still shows connected ..in google play it shows no connection.
Tried the 526 trick but it didn't work.
Using static IP doesn't even allow to connect it to laptop(guess some issues with intel my wifi technology) forget browsing the internet.
I 'm using 2.3.6 and my device is still unrooted.
Any solutions? Thanks in advance.
Mostly the problem is on laptop side
