Wifi Says Disabled, yet it works for other devices
Status
Not open for further replies.
hookturn
Recently I noticed I could not get wifi in my apt. I always was able to in the past. I'm sitting about 10 feet from the wifi router. I've looked everywhere on my phone to try and solve this but to no avail. Any help will be greatly appreciated.
Thanks
So what exactly says "disabled"?
When I turn off roaming and turn on wifi, it used to automatically hook up. My TV and PC provider is Xfinity so that is the name of the Wifi I connect to. So now I go to settings>network & Internet tap wifi, it says not connected, I tap it again and it shows a list of Wifi signals, under Xfinity (the one I use) it says disables
When you hold down the power button, does it come up with "restart" or "off", just like a PC.
OH, ya. Never bothered to restart, just did. Haha what a dummy, do that on my pc for many things. Just tried it no help, still says disabled.
So what if you press and hold the network name: that should give you options, one of which hopefully will be to re-enable it.
(I'm guessing that you accidentally hit something that told the phone to forget this network).
I"m taking it to the Verizon store where I bought it. They can figure it out. Thanks for your hlep
Status
