Hi
I noticed this a while ago and was wondering if someone else has the same problem.
The problem is that when I'm connected to a WiFi network, the WiFi signal bar (the one to the left of the cell network signal bars) always shows up with just one blue line (as if the signal were weak), but this doesn't change no matter how close to the router I put the phone. I know the problem isn't with the signal because if I go to the Wi-Fi settings screen I can see several bars to the right of the network I'm connected to (and that number of bars varies as I move away of the router.
Any ideas to fix this will be really appreciated.
Thanks
Thanks
