nyydynasty
Android Expert
i'm trying to setup a tasker profile that will turn off and turn back on wifi while connected to my home wifi network. I have two AP's setup in my house and all the wireless devices we have will not switch to the stronger AP unless the previous signal drops and then it will reconnect to the stronger signal. So if I can get it to toggle the wifi switch on the device when, for instance, the wifi signal drops below 2 bars, then it will always connect to the stronger signal.
The reason I'm trying to do this is also because there are a couple of rooms in the house where you'll be connected to the weaker AP, even though another AP is stronger/closer. Unless you manually toggle wifi, the device is very slow to load data.
thanks
thanks
