I'm having a problem with my G1 maintaining wifi connections. Since Friday it has started dropping the wifi connection and reconnecting over and over when I leave the phone sitting for a while. If I use it then it normally stays up. But if I sit idle it will start switching from wifi to 3g constantly and the battery will drain very fast. When it does this it the connection goes from connected to unsuccesful on the wifi options screen. Now after the RC 29 update the switching appears to have stopped but once left idle I wake it up to find it connected to 3g. If I use it constantly it stays connected.
It has done this on multiple wifi networks so I don't believe it is my home router. Could I be missing a setting somewhere.
