wifi wont stay on
  • Start date Start date
We may be better able to assist you if you tell us what kind of tablet you're using, what version of the system software you're on, etc... the more information you can provide, the better!
+1 to what doniago said
Also, an easy thing you could try would be to go to a public wifi spot and see if you have the same issue. If not, it implies the problem is with your router/ap.
