wifi wont turn on
  • Start date Start date
A
Android Question
Guest
i have an e-matic android tablet and when i try to turn on the wifi it just says turning on wifi and does nothing. i have wifi at home and at work and it works at neither place.
Welcome to Android Forums!
We need a little more information with a problem like this. Has the wifi ever worked for you? Did you change anything right before it stopped working? Please resubmit your question with as much as you can remember.
Thanks!
Hello, thanks for your question. ematic i don't know very much about that device as a whole. so i will give you some generic advice that tends to work for most.
1.Checking the wifi passcode (try it without one and with one)
2. Restarting, I feel I may be being silly but have you shut it off for a long period of time then tried to connect to the wifi?
3. Factory Reset, This may be a tad bit drastic but it works quite a bit it just clears out and refreshes.
Please get back to us if any of these work or if they don't work.
check Ematics website ,locate your device and see if there are any issues reported by manufacturer regarding wifi connectivity. And also if there are any device updates. If there are updates,follow ematics instructions to install. If its a reported issue,an update may resolve it. Also go into settings,WiFi,advanced WiFi and try different band settings. May gain your signal.www.ematic.us/tablets
