Wifi
I have a Droid and a home WIFI system but I cannot connect to it with the Droid! I can connect to free sites such as Starbucks, but it will not connect at home. Any suggestions?
What type of router do you have? There is an issue with some N routers where devices which are not N will not connect. Try turning off N mode on the router.
The router is a Linksys G router. I cannot see anything in the set up that should prevent the phone from accessing the WIFI. It says that it ahs remembered the network, but will not connect.
