Help Wifi
D
Deleted User
Guest
Anyone else having Wifi issues? Driving me crazy at the mo.
Got a bloody good Wifi signal in the house, every other phone is fine, yet mine keeps going to limited connectivity. Even when it doesn't say that it won't load anything.
Got a BT infinity set-up at home, wifes Z1 compact has no issues at all, and the kids Iphones are fine too.
If I turn the phone off, it's fine for a few minutes, then poor again. Same if I forget the network then reconnect.
Phone or a settings issue?
Sorry Can't help you there.. I've had my Z2 for just about a month and a half .. Not had any issues with wifi at all..
I have SKY broadband tho..
Hopefully someone with BT Infinity can chime in..
Have you tried disconnecting the wife's and kids phones from the wifi just to see if that makes any differences?
Actually after doing some digging on the Sony forums, seems there is an inherrent issue, and it is quite a widespread problem. It's not the router or home issue, but definitely the phone.
You know there is a recognised issue when sony actually have a fault finding guide on a product less than 2 months old
I`ve been having a problem where it sometimes wont flip over to mobile data (yes, its turned on), when I either lose or turn off the wifi.
I end up having to reboot.
Think I`ll go look for the fault finding site you mentioned.
I had to switch Location Based WiFi off because it wasn't connecting again.
Otherwise the signal seems strong with my BT Infinity.
Do you have a link to the forum you mentioned.
