http://www.willmyphonework.net/Can I use a iPhone 5s model Me341lla with tmobile and metro pcs if unlocked? Or just ATT phones
then I believe it should work for Sprint, Boost, & VMJust Googled it and it's a CDMA so no go
Yep.The guy said it's unlocked for GSM, is that possible?
It would need gsm.radios installed... Go to the apple.com look for your device specs. If its a cdma you would have to flash gsm.radio n blobs. That's a long run... If it international you should be good to go but then you need to jail.brake... N find how to tweak you radios scripts. To be able to run radio n to stick. If its a gsm version you should nb good to go.The guy said it's unlocked for GSM, is that possible?
Jajajaj you beat me up... Good job n thnx for your help.Yep.
http://www.everymac.com/systems/app...s-a1533-cdma-verizon-north-america-specs.html
Look it up on the page I gave as the A1533 CDMA.
Compatible with T-Mobile.
