The answer is that it will probably be the same as others, but if Tracfone modify the software then there is the possibility that it might not, or more likely that it will be delayed. I'd think that major updates would come if they are released for other versions of that phone, but only Tracfone could say for sure as they make the final decision (if they modify the software for themselves).
That's assuming that other models are getting it. A carrier model won't get it if others do not.
