will not turn on
  • Start date Start date
A
Android Question
Guest
Motorola droid max , Verizon . will not turn on tried to reboot with power button and volume down key .....NOTHING!! Any ideas???
Welcome to Android Forums!
Not sure why you're trying to turn on the phone using a combination of keys, when the power button alone should be sufficient to power up the device (unless you're trying to access the Recovery or Bootloaders, which I do not recommend for the casual user).
If the phone will not power up under charge with the power button, it sounds like a trip to Verizon is in order for a warranty replacement.
Hope this helps :)
