Hi,
I have become frustrated to the point where I can't continue with this HTC One M8 rooting project. It's my first attempt and it isn't fun anymore. I am willing to pay someone who could walk me through every step in hand-holding mode. I can reply with descriptions of what happens after every step (and pics of the phone/PC screens if my new Android Forums account allows it). Despite having spent weeks on this I still don't understand the lingo so exact phrases and descriptive wording would be very helpful. Also I'm not worried about losing any data on the phone or installed 64GB SD card. The phone is essentially new at this point with no important stored data.
This is a new 2014 HTC One M8 unlocked AT&T USA model I purchased a while back on ebay. I have done the following, forgive the probably inaccurate terms:
* Installed ADB package on my PC.
* Went to HTCDEV and did the bootloader unlock procedure.
* Followed instructions to use Sunshine to make S-off and change CID value to 11111111
* Installed TWRP, not sure which version as this is very confusing. It might have been me.twrp.twrpapp-26.apk or openrecovery-twrp-2.8.5.0-m8.img. I don't know which one worked.
* Flashed new firmware, supposedly so that the eventual newer ROM (newer than 4.4.4) would be compatible. This FW version is also confusing due to multiple designations for what seems to be the same thing, but this particular file was called 6.20.502.5. I selected this one because the "502" was the same as part of my original software # 3.42.502.1. It was the only way I could figure to select a compatible but latest FW. I'm guessing 502 means US AT&T model.
At this point I could go no further. Now the phone starts up and hangs at the HTC screen. I can press Power + Volume Up to turn it off but it will restart in a couple seconds and hang at HTC again. If I press Power + Volume Down as soon as it powers off I can get into the "Fastboot USB" screen. From there I tried random things but can't proceed. It appears that I lost TWRP on the phone because of the firmware update (it had worked before) because now all I get in recovery mode is the basic Android Recovery app. I don't have a clue what I'm doing and research is making it more confusing.
My understanding is that this can still be recovered/fixed by an expert.
The phone is just a hobby but a $230 hobby with accessories
so I'd like to give it a shot before giving up.
The only thing I wanted to do was create a phone which would bypass the tethering check/denial process. I'm perfectly happy with the way it works otherwise. It would be nice to get an upgrade from 4.4.4 since it is so antiquated I'm afraid some functions will become incompatible over time unless I move to something like MM or Nougat. So a minimally buggy stock or stock-like ROM that bypasses tethering restrictions would be perfect.
Finally, here is some current data from the Fastboot USB screen so you might be able to tell how screwed up it is:
*** Software status: Modified ***
*** RELOCKED ***
M8_UL_CA PVT SHIP S-OFF
CID-11111111
HBOOT-3.19.0.0000
RADIO-4.0.U605761@60220A
OpenDSP-v56.2.2-00593M8974_F0.0126
OS-6.20.502.5
eMMC-boot 2048MB
April 14 2016,19:39:46.27667
Thanks for reading this long help request!
so I'd like to give it a shot before giving up.The only thing I wanted to do was create a phone which would bypass the tethering check/denial process. I'm perfectly happy with the way it works otherwise. It would be nice to get an upgrade from 4.4.4 since it is so antiquated I'm afraid some functions will become incompatible over time unless I move to something like MM or Nougat. So a minimally buggy stock or stock-like ROM that bypasses tethering restrictions would be perfect.
*** RELOCKED ***
CID-11111111
HBOOT-3.19.0.0000
OS-6.20.502.5
eMMC-boot 2048MB
