Wiped and formatted SD Card. now???
Skrail
Ok so I wiped and formatted my SD Card to FAT32. I am in the reboot/recovery screen of my android with ClockworkMod and I noticed when I turned on USB Mass Storage, the SD Card is readable but there is nothing on it now. Is there any important files I am going to need to put on the SD Card for my android to function correctly on start up/running? Or will my android automatically put the correct files on the SD Card on boot? Haven't tried booting it yet lol..don't want to screw it up.
If there's nothing on the SD card then you should not even be in CWM recovery. Should just do a normal boot.
