Wired (boom) headset - Xperia Mini Pro
Terry1100
Member
Hi All
Just got my Xperia Mini Pro - and loving it.
But I am not a fan of bluetooth - I like my headset to be physically plugged in to the phone - and I like a boom.
Unfortunately, my current headset is incompatible
Research tells me that iPhone, Blackberry (I think mine is this type) and HTC are different - but what is the Xperia Mini Pro - which type do I want.
Even a confirmed pinout to allow me to make one would be helpfull.
Better yet, does anyone know of a wired boom headset (or adaptor cable) that is definitely compatible with the Xperia Mini Pro. If there was a genuine SE model I would buy it without hesitation.
TIA
Terry
Answering my own question.
IT appears that the Sony uses OMTP type pinouts which is the same as Nokia (and Samsung) but NOT the same as iPod/iPhone, HTC and Blackberry which use CTIA pinouts.
Don't make the assumption that a "Smartphone adaptor" will work - it wont.
Until I find the right headset buddy to allow me to use a PC (2x3.5mm) headset, the Nokia AD-53 adaptor should do the trick
FURTHER UPDATE
The Nokia AD-53 should allow the use of an Xbox headset. I'll confirm that shortly.
FURTHER FURTHER UPDATE
The Nokia AD-53 is the solution of choice. It is neat, high quality and wroks well with a 2.5mm headset. It allows a wide choice of headsets including XBox. The "Headset Buddy" (and it's StarTech.com equivalent) DO NOT work on the Mini Pro
