wireless charging, all about
Leob
Is there a difference between Fast and Regular wireless charging?
Is there any disadvantage to Fast wireless charging?
What are the official Samsung catalog numbers for Fast and Regular?
What is the best 3rd party vendor product for Fast and Regular wireless chargers?
Is the 3rd party product as fast etc?
Would the Note7 work on these S7edge wireless chargers?
Any 3rd party products to avoid?
Any other considerations?
Weblinks appreciated as helpful.
Thanks.
It's obviously faster to recharge your battery this way.
It can make the battery displace more warmth as your fast charging. The phone will feel warmer.
I did buy one online and am now refunding it as it's a fake. I bought the fast charging stand and it has no fan in it when it should and it'll only charge normally.
I'm now buying one from Samsung directly. Stay away from eBay and Amazon ones that has a price that looks to be too good to be true. Read reviews.
I have a standard charging pad for my bedroom and want a fast charger for my living room.
Some say you can hear the fan so not so good for the bedroom.
As far as I'm aware it's the same charging specs so yes they should charge OK on the same pad / charging stand.
You'll need to use an original Samsung fast adaptive charger cord in my opinion to get fast charging through the pad or stand.
Which component or components determine fast wired charging - the plug-in-adaptor-charger and/or the cable(usb-to-microusb)??
Is there a difference between Fast and Regular wired charging?
Is there any disadvantage to Fast wired charging?
What is the best 3rd party vendor product for Fast and Regular wired chargers?
Thanks.
For Fast Wireless charging, which component or components are essential to it? The wireless pad and/or cable-going-to-the-plug-in-charger-adaptor and/or the plug-in-adaptor-charger??
The wireless charging pad must be the fast charging version.
The plug charger needs to be the adaptive fast charging version too.
Fast charging then needs to be toggled to On in the phones settings.
The charger that comes with the Samsung Galaxy s7 edge is a fast adaptive charger option.
If you try using a charger bought from elsewhere that isn't fast charging specs then it won't fast charge the phone.
