I am using the same charger ad you are. The Tylt vu qi.I have sleep mode enabled on my T2, from 11pm to 5am each day. I am using the Tylt Vu Qi charger, purchased a year and a half ago that I used with my T1. My T2 is always charged at 100% when I take it off of the charger in the morning. Not sure what to tell you. What wireless chargers are you using. Maybe someone else will be able to chime in to help you.
The AC power circuit? Seriously?Maybe the circuit the chargers are plugged into is disconnecting?
... Thom
Well AC power does not simply the disconnect. Does not happen. You either lose power , breaker trips or the power is constant. I am going to try something tonight. I am going to make note of the battery level before it goes into sleep mode. Sometime it goes into sleep mode BEFORE it goes on the charger. I a going to try 3 different scenarios. No sleep mode, sleep mode before putting on charger, and sleep mode after it is on the charger. Who knows it could be just a rare occurrence.Yes.
I never use night mode but do have the seam phone and charger.
Another person here reported no problem with the same phone and charger and night mode.
What happens if you don't use night mode?
... Thom
And it has worked each night. I also have a otter box case on it which I think makes placement even more critical. I am thinking that the phone was out of alignment. Also on the phone, if I don't see the charging 'ring' come up on the phone, chances are the phone and charger are not aligned.
Funny, I was going to ask about a case but it slipped my mind.I also have a otter box case on it which I think makes placement even more critical.
