Help Wireless internet not working in sleepmode (standby)
Jiro87
Hi all,
I have an problem with my tablet. I am using this device to listen to the radio, but after a couple of minutes it goes into the sleep modus (screen turns black, etc.). A side effect is that the wireless internet is disabled too.
I have tried several option, like change the settings into never disconnect from wifi. And i have installed diverent apps who claim to fix the problem that the wifi turns off.
Well, those didnt work either. So here i am, asking you guys for some help.
Summary: i want that, while in sleep modus (standby), my wifi does not stop working.
I hope one of you has the solution!
oh yah it does have a pretty aggressive power management. The only way I can get my streaming music to continuously play is with the power plugged in (tablet in dock/cradle) and Settings - Applications - Development - Stay awake while charging. Unfortunately it's not portable, and the screen is always on but it'll dim after a while...
Thank you andr01d, best answer yet!
I just have to buy a extra charger...
Still, the question remains, i would love to hear a portable solution.
