I dont know what has caused this but each time I reboot my wireless is on and the screen timeout is set to 30 sec(my setting is 10min) even after adjusting it reverts back to these settings on reboot. Does anyone have any idea what is causing this?
no idea what would cause this. did you perhaps install any apps lately? try removing all the apps that you think may mess with your settings. test each one at a time. if you still cannot fix the issue then do a factory restore. good luck.
