Hi, I am trying do a few things, I hope someone can help figure it out..
1. I am trying to get rid of the chinese android market on this tablet. I found the file com.wonderappstore.wondermedia-device3-release-110408.apk in the /app file, however I cannot delete files from this folder, or at least have not be able to figure it out.
does anyone have advice on how to remove that application?
2. that weather widget on the home screen only displays 24/military time, i.e 7:15pm is shown as 19:15pm. I cant find the settings or options to change this to standard 12 hour time, is this an option? and can this widget be removed from the homescreen?
I have not rooted this device as that seems a bit beyond my knowledge at this point, so I am hoping there are fixes without having to do that.
Thank you!
Chris
Thank you!
Chris
