WoodrowB
I have only been using my new N5 for a week or so, but the GPS performance is not what i'd hoped for.
It is quick to lock onto a position...quite the change from my N4.
However, it seems to constantly be shifting my position within about 50' or so.
Using a GPS app shows that the signal strength of the different satellites is much less than the same app showed with the N4.
Also, my onboard compass seems to be about 90 degrees off....and no amount of "figure-8" waving helps.
Any observations from y'all?
