wont boot up or hold a charge
  • Start date Start date
A
Android Question
Guest
I have a mid tablet model m720b. It wont hold a charge. And now its dead and wont turn out. Thx
Hi, and welcome.
It sounds like a problem with either a bad battery, or a bad charger.
Does the charger work with other devices? If it doesn't, use a different charger for your device.
If that doesn't work, try changing the battery.
Hope this helps.
