Wont connect to car stereo
I have an s8+ that I am trying to use with my android car stereo I just bought, when I connect my phone to the stereo it tells me I need to install easy connect. I did but I still cant connect, any help?
What exactly is this "easy connect", is it installed from the Play Store? Are you using Android Auto? Also what make and model is your car stereo?
Tried android auto, didn't work.
Can your car radio connect via Bluetooth? If so do that you have to pair both devices
Ok, so you should be able to play your music off the phone to the car radio.
Fire up a music player app on the phone and you should be good to go.
Not sure if YouTube red will work via Bluetooth. How about your stock music player?
