won't turn on
  • Start date Start date
A
Android Question
Guest
I have a Samsung galaxy tab 2. Last night I put it to charge and was working fine before I went to sleep. Today it doesn't wanna turn fully on. It doesn't go past the Samsung title in the screen it sorta freezes right there. I don't understand what's going on. I've tried holding down the power button but nothing happens. I didn't leave the tab to charge throughout the whole night. Once I layed down in bed I disconnected it. My cousin put it to charge to see if anything happened and instead of the battery looking yellow like it normally does when it's charging while being turned off the battery was blue. Can someone please help me? Please and thank you.
Make sure you are using the factory charger and factory cable. Try turning it off and charging it that way as well. If you're charging it via your PC that as well might be a problem.
good luck
