WORKING CORRECT APN's(FIX FOR CRICKET MMS ONLY)
blueeyiz702
Member
first to do on list,is go to play store. download free app called apn shortcut settings and install. once installed click on it will take you to black screen,at bottom click new apn and put in as follows:
Name; Cricket
APN; wap.mycricket.com
Proxy;wap.mycricket.com
Port;8080
Username;yourcellnumber@mycricket.com
Password;cricket
Seerver;leave like it is(should say not set)
MMSC;http//mms.mycricket.com/servlets/mms
MMS proxy;should say not set
MMS should say not set
MCC;310
MNC;016
Authentification type;CHAP
APN type;*
APN protocol;ip4/ip6
You then have option to save, wich you do! reboot phone and send mms to your own number and should get instant sent! Ive used and always work reguardless of rom im using!! they where taken from stock fresh from store ascend 2,this is how they have set and works like charm.
