F-Droid is fine.
'Nooooooo!
Scary message from Google, telling me not to go somewhere besides Google!'
Yeah, we all fell for that at first.
Look at it this way:
Google spreds more malware than anyone else on the planet, and do the least for security.
One look at all the thousands of anti-virus, boosters, cleaners, battery savers, and other worthless tripe on the Play Store- and the insidious permissions these apps 'require'- it soon becomes obvious what a sham Google is perpetrating.
Millions of devices have been infected from apps downloaded from Google, that Google had deemed 'safe'.
F-Droid?
Never a single issue.
Why?
Because the folks at F-Droid take every single app sent to them and decompile it entirely.
This ensures that nothing screwy is going on.
Then they recompile it themselves before it is even available on their site.
This does slow down the release of updates, but it also insures the integrity of F-Droid and the apps therein.
No other appstore that I know of goes to this extreme.
Another benefit of having the F-Droid app is that it will automatically get the correct versions of apps for your device.
Any utility apps, I look to F-Droid first.
Other apps as well.
Some apps are available on both Play Store and F-Droid, and I will still take the F-Droid version.
This is because although the apps may function the same for me, the Play Store version will almost always include Google spyware (Firebase, Services, etc.) that I have no interest in allowing on my devices.
Here is the legitimate link for F-Droid.
Let me know if you need help setting it up, however, it is pretty simple.
https://www.f-droid.org/
Once you get the app settled in, you will enjoy it more (~900 apps more) if you tap this link and allow it to be added/shared with F-Droid.
https://apt.izzysoft.de/fdroid/repo...7B6D966BE743BF0EEE49C2561B9BA39073711F628937A
If you already have NewPipe, there is also a repository from them as well.
https://archive.newpipe.net/fdroid/...97DB914A2751FDA1D02FE2039CC0897A462BDB57E7501
Do you use Bitwarden?
Ditto as above.
https://mobileapp.bitwarden.com/fdr...CC47C561C5726E1C3ED7E686B6DB4B18BAC843A3EFE6C
Adding these to F-Droid allows F-Droid to display these apps which are not a part of the basic F-Droid experience.
It also allows for faster updates of some apps, especially NewPipe.
(This is important because at certain times Google will try to make things so that NewPipe (and apps like it) will no longer work. The devs can quickly respond (usually within hours) with an update to fix the issue.)
