Accessories Would this help extend battery life?
sergey
I've heard of people trying to get extended batteries, but these things are bulky and expensive. Amazon shows the Mugen 2400 mAh battery for the G1 at $67 and it's big.
Has anybody heard or tried using the Just Mobile Gum Power Packs?
Review: Just Mobile Gum and Gum Pro Portable USB Power Packs | iLounge
For $45 you get 2200mAh
For $62 you get 4400mAh
Bascially it's a small black box the size of a pack of gum. You connect it to your gadget of choice using a USB cable. Would this work with the G1? Thought this might be of help to the Android users out there.
its a portable charger, I have one, it doesnt extend your battery, its just a charger for when you arent around a plug
