Hi,
I've been trying to make this LG VS920 to be used with my Indonesian operator Smartfren.
At first I have this phone it does work with Smartfren RUIM, but the signal is not stable. Then when I tried to use NV, my operator doesn't allow to pass akey anymore, so I revert it back to RUIM.
Then the phone got bricked because I change NAM setting in RUIM mode, already bring it back on with restore using LGNPST.
Then flashed to stock deodexed, after that going to CM10.1, after that going back to stock deodexed, but then I noticed that I can use NV mode again, before when I switch to NV using DFS the phone doesn't say that it need SIM Card to operate, but now it said that need SIM to operate...if I put my RUIM or SIM from VZW the notification gone but it can't get signal.
Already tried to flashed back (without removing CWM) to stock using LGNPST but still can't get to NV only...I tried to get to NV because the phone data is not good although it said 3G and connected to EVDO but very slow.
Is there anyway to get my NV only work? btw if I plug to USB the USB mode still can't recognize, I still have to reboot the phone, is the CWM still installed? Although I already flashed it to stock using LGNPST.
